April 27, 2023 at 12:47 am
nurhalimputra117
SubscriberHi everybody,
Here I'm doing a floating breakwater simulation to find out the reaction of the fixed pile strength, in overcoming the movement of the pontoon due to incoming waves. there are 2 objects, namely the pontoon, and the fixed pile.
I need 3 solutions :
1. How much force/moment is acting on the fixed pile, due to the force reaction from the pontoon movement.
2. How do I simulate the visual animation, because I have tried, but the fixed pile does not react to the motion of the pontoon (the fixed pile penetrates the pontoon body).
3. How do I simulate the force/moment contours into a Hydrodynamic Diffraction wave simulation. Because I only found the contours due to the influence of waves, not because of the motion of the pontoon.How are the settings in AnsysAqwa, to get these 3 solution points. Thanks, I hope someone can help me
April 28, 2023 at 11:38 am
Yu Bi
Ansys EmployeeHi, you need to define fenders on the fixed pile or pontoon to get reaction forces between the pontoon and fixed pile.
You can turn off Include Incident/Diffracted/Hydrostatic Wave option in the Pressures and Motions results and only include radiation wave which is caused by the motion of the pontoon.
May 7, 2023 at 5:52 am
nurhalimputra117
SubscriberI have set the fenders at each point of contact between the fixed piles and the pontoon. with settings as below. but as a result, in hydrodynamic diffraction, the fixed piles still penetrate the surface of the pontoon, when moving due to incident waves. can't this be simulated in hydrodynamic diffraction?
5386
3367
2471
1310
1022
