October 18, 2018 at 7:48 pm
Weiqiang Liu
SubscriberHello, everyone,
I am trying to simulate surface reaction with a micro-combustor by importing chemkin mechanisms into fluent. however, I met two problems.
First, I need to know the species ID of some particular species. Since I have both gas phase species and surface site species. I wonder what is the sequence of species in the species mixture panel, gas phase species first or site species first?
Second, I want to use UDF to define the surface reaction rate of some surface reactions. Since I have 50 surface reactions to define, I want to use a 'for' structure to loop over all the reactions I want to define according to their ID. How can I do that in ANSYS fluent?
Thanks very much!
weiqiang
October 18, 2018 at 8:22 pm
DrAmine
Ansys EmployeeCan you check the customization manual after DEFINE_SR_RATE if it does answer your question? The gas species are always listed first the others later telling you the site density.
October 18, 2018 at 8:54 pm
Weiqiang Liu
Subscriberthanks very much.
So the gas phase species first and then site species. The customization manual after DEFINE_SR_RATE only tells me how to define surface reaction one by one. Like ‘if (STREQ(r->name,”reaction-1&rdquo
) *rr=100’
this tells me how to define reaction rate according to reaction name. But how can I define reaction rate by reaction ID. By doing so, I can just use a ‘for’ struction to loop over all reactions very easily. Otherwise, I have to define the reaction rate one by one.
best.
weiqiang
October 18, 2018 at 8:55 pm
Weiqiang Liu
thanks very much.
) *rr=100’
best.
weiqiang
October 19, 2018 at 5:31 am
DrAmine
Ansys EmployeeReactions can be identified by their name through the r->name statement and I think this might help here:
if (!strcmp(r->name, "reaction-1"))
.... /* r->name is identical to "reaction-1" ... */
I am not aware about accessing the reaction's ID's as it is not a part of the reaction structure.
October 19, 2018 at 12:56 pm
Weiqiang Liu
SubscriberThanks very much!
another question, I defined some surface reactions in material panel and I loaded my surface rate UDF normally. Then do I need to hook the UDF or something to make my UDF effective? or I just need to run the model directly.
Best.
Amine
October 19, 2018 at 2:49 pm
DrAmine
Ansys EmployeeYou need to hook the UDF as described under DEFINE_SR_RATE. If everything is complied and loaded properly then just run the case.
October 19, 2018 at 4:14 pm
Weiqiang Liu
SubscriberYes, everything is compiled and loaded properly. So I just need to run the case without any other manipulation?
I mean DEFINE_SR_RATE is no like DEFINE PROFILE ,by which I need to hook in inlet BC panel .
for DEFINE_SR_RATE, I just need to build and load?
thanks so much!
weiqiang
October 19, 2018 at 4:25 pm
DrAmine
Ansys EmployeeYou need to hook it under user defined function hooks.
October 19, 2018 at 4:44 pm
Weiqiang Liu
SubscriberThanks very much. I am totally a new user of ANSYS fluent. Thanks for your patience !!!!
October 19, 2018 at 4:59 pm
DrAmine
Ansys EmployeeYou are welcome. I recommend that you carry out some Tutorials to get familiar with a lot of Fluent panels. The tutorials are available within the online Help.
October 19, 2018 at 10:06 pm
Weiqiang Liu
SubscriberThat’s very nice of you!! I’ll go through the tutorials.
2564
2078
1289
1106
459
