Discovery Import
Discovery Import
Reactivating a License on a new Computer
    • derekkninja
      I removed a license on 1 computer and are trying to activate a new computer,
      I tried this:
       On the machine on which you want to activate a subscription, open a command window in the following Ansys installation folder:
              2021 R1 or later: \ANSYS IncvXXX\licensingclient\winx64
      And it gave a :success notification
      But is not allowing discovery to run.
    • Subashni Ravichandran
      Hello Derek Knijn
      I can see from my end that the trial license you are trying to use is already activated on one device. Can you try deactivating on this device before activating on the other one?
      To deactivate, please follow the below commands.
      cd C:\Program Files\ANSYS Inc\v2xx\licensingclient\winx64
      ansysls_client.exe -DeactivateAllEntitlements
      To activate on the other device, you will need to run the below commands in sequence, with the activation ID on the second command.
      ansysls_client.exe -ActivateLicenseEntitlement (ActivationID)
