October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThere is no requirement for any add-on license to read a 2D PDF that contains boundary representation data (B-Rep data). If B-Rep data is not contained by the 2D PDF, user can first convert the *.pdf to *.jpg and then import that in SpaceClaim for creating new geometry.
October 4, 2017 at 2:39 pm
nselvara
Ansys EmployeeHow to read 2D PDF into SpaceClaim?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
