Tagged: batch-mode, crash, mechanical, post-processing, random-vibration
March 4, 2022 at 7:40 pm
anarayanan
SubscriberHi all,
I am facing issue on Ansys Mechanical when trying to read random vibration results. Version 2019 R3. I run the solution in batch mode on HPC and import solution to Mechanical to read results. When I read result, mechanical crashes. Details are given in following link: https://forum.ansys.com/discussion/36752/mechanical-crash-reading-solution-file-batch-mode
I also have noticed that decoupling the system eliminates this error.
I was wondering if there is a way to read results on mechanical without coupling the system with Modal analysis. I have tried a stand alone Random vibration module on WB to read these results however I get an error saying 'You need at least one structural load to proceed with the solution.'
Is there an alternative way to read results of random vibration as I have the solution files of the system?
March 7, 2022 at 3:35 pmViewing 1 reply thread- You must be logged in to reply to this topic.
2534
2066
1285
1104
459
