TAGGED: fdtd, file-structure, format, lumerical, structure
June 27, 2023 at 9:27 pm
Tianyu Liu
SubscriberHi,
I'm a Lumerical FDTD user. We want to import a structure for our simulation. I see there're two options for the format, GDSII or STL, but what we have is txt. file. Is there a way to import a txt. file as a structure to Lumerical? or is there a quick way to convert txt. to STL or GDSII? Any recommendation is appriciated!
Thanks,
Tianyu
June 28, 2023 at 1:01 am
Devika Padmakumar Nair
Ansys EmployeeHi,
The preferred data format is in Matlab. Matlab preserves the original data and unit.
Since your file is in .txt, you can try using combination of readdata – Script command – Ansys Optics and addpoly – Script command – Ansys Optics to import the geometry in FDTD.
Thanks
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4504
2971
1449
1322
