May 21, 2022 at 10:13 am
PJThejash
SubscriberHello,
In the ansys Mechanical, adding a real constant is not supporting. What will be the issue?
May 22, 2022 at 2:11 am
SubscriberAdding a Real constant to an object in Mechanical is done using a Command object. The button to add a Command to an object in the model is on the Home tab. Command objects can be used to convert a previously modeled element such as a spring from an element type that is supported within the Mechanical Details window by using APDL commands that change that element to another type and provide the Real constants needed to define it.
3812
2589
1845
1244
600
