Ansys Products
Ansys Products
Real-time monitor the progress of Fluent calculation when using RSM
    • MemoriseXuxu
      I have finished configure the RSM. Thank you so much. But I have another question. Is it possible for me to monitor the residual curves real time if I submit a Fluent Job from Workbench. I try to right-click the solution and select ‘show solution monitoring’ and set progress download interval as 5 seconds. . As a result, it doesn’t show up real-time. Instead, only does the job finished can the curves shows. But I wan to see it real-time. Is it possible to be?
      Best regards
      Memorise
Viewing 0 reply threads
