November 25, 2019 at 4:13 pm
Dom27
SubscriberHi all,
In Workbench it ist easy to rename a system. But the .cfx .def .out .res .cst files will stay at the old name. Is it possible to rename them as well?
Thanks,
Dominik
November 25, 2019 at 4:43 pm
Ansys EmployeeAll the files within Workbench are labelled based on the system structure. Renaming is a really bad idea and likely to break something. If you export the CFX files and run in standalone mode you can name all files as desired as you're nolonger using Workbench.
5242
3299
2469
