March 16, 2023 at 10:37 am
Vaso M.
SubscriberHi,
I am trying to write a code to solve a plate (meshes with SHELL181) which is under pressure and it has initial deformation. I detached the nodes from the mesh (MODMSH,DETACH) and I modified them (NMODIF). How can I reattach them to the mesh in order to proceed to the solution?
Thank you
VM
March 16, 2023 at 2:21 pm
Ashish Khemka
Ansys EmployeeHi,
You can try node merge.
Ashish Khemka
March 16, 2023 at 2:33 pm
March 16, 2023 at 2:37 pm
Ashish Khemka
Ansys EmployeeHi,
Can you try increasing the tolerance for the NUMMRG command?
Ashish Khemka
March 16, 2023 at 3:05 pm
Vaso M.
SubscriberTo be honest I am not sure how to do so. The link sends me to another site, where I have to complete a customer registration, but I have access to ansys from my university.
Thank you for your time,
VM
March 16, 2023 at 3:06 pm
Ashish Khemka
Ansys EmployeeHi,
Please see if the following link helps you: How to access the ANSYS Online Help
Ashish Khemka
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3930
2649
1861
1272
610
