Recirculation Boundary Conditions
    • eik92
      Hello,nHow can I set recirculation boundary conditions? I just checked TUI functions but I could not find any proper solutionsn
      If you mean the older recirculating bc in Fluent the commands have changed. As the first stage is a hidden command I'm unable to share that, if your supervisor has access to the Customer Portal they will find a solution with the commands on there. nOtherwise you can use a UDF to find the mean values removed on a surface and put them in on the other surface. n
    • eik92
      The mean values (like pressure, velocity etc) does not fit my case.n
      You need to pair values exactly? What are you modelling?n
Viewing 3 reply threads
