January 16, 2023 at 7:17 pm
MohannadS
SubscriberMy current workstation consists of:
HP Z820
Intel Xeon E5 2670 v03.06
64 GB RAM DDR3
4GB NVIDIA Quadro 6000
I am currently doing my research in 3D turbulent simulations with mesh approx. 10M elements. My workstation is a bit slow but I have a $1000 to buy a new workstation.
Can you recommend a new build for a better workstation?
January 17, 2023 at 5:00 am
SRP
SubscriberHi,
I recommend you to plrease check this forum discussion: Please recommend the configuration of the computer workstation (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thank you
Saurabh
January 17, 2023 at 8:02 am
MohannadS
SubscriberI appreciate the guidance. I have checked that discussion but the budget difference is large. Therefore, I started this discussion as mine is only 1000 USD
January 17, 2023 at 10:42 am
Ansys EmployeeHow many parallel licence keys have you got access to?
January 17, 2023 at 10:46 am
MohannadS
SubscriberEven though my workstation has 20 physical cores and fluent detects 32, I am only able to run each simulation at a maximum of 12 cores.
January 17, 2023 at 11:36 am
Ansys EmployeeOK, that's the licence limits. One issue with the high core count chips is memory and data passing: the bottleneck is getting data between the cores. What models are you running, and if you monitor cpu & RAM how does it look? Does the current machine have one chip with 20 cores or two chips with 10 each?
2524
2066
1279
1096
457
