August 2, 2019 at 12:46 am
LukeM
SubscriberI am using the RNG k-ε model with Menter-Lechner wall treatment, and I want to ensure I adequately handle the near-wall region. Is there a recommended range of y+ values for the Menter-Lechner wall treatment? I understand the model was specifically designed to be y+ insensitive (see the "Menter-Lechner ε-Equation (ML-&epsilon
" article in the user manual), but I want to avoid any less-accurate predictions for flow from the model. For example, should I avoid the 5
Luke
August 2, 2019 at 11:15 am
Ansys EmployeeIt depends. What are you trying to model?
August 2, 2019 at 2:26 pm
LukeM
SubscriberAt the moment, I'm modeling turbulent, single-phase pipe flow. But I will eventually be modeling turbulent, stratified flow through fairly complex geometry. I am also solving some UDS equations. I suspect that accurate predictions of the boundary layer are crucial for my system.
August 2, 2019 at 2:30 pm
Ansys EmployeeAdding multiphase will make it much more interesting!
General theory is if you want accurate drag etc y+ = 1.
August 2, 2019 at 2:41 pm
LukeM
SubscriberWonderful. Thank you!
2706
2146
1357
1144
462
