March 16, 2022 at 3:10 am
laserboi97
SubscriberHi, I'm trying to calculate the approximate losses in a wave guide structure with a layer with a specific n,k defined (0.055, 3.7).
Using the mode solver, I obtain a modal loss is 70 dB/cm.
I have also calculated the confinement (power in lossy layer / overall mode power) in this lossy layer to be around 0.00062. The absorption coefficient converted from k = 3.7 is about 8.3 x10^5 /cm = 3.6 x 10^6 dB/cm. So the modal loss I approximate to be around 0.00062 * 3.6 x 10^6 = 2232 dB/cm, which seems very different to the loss calculated in the solver.
Am wondering if anyone is able to explain this discrepancy and/or if there's anything fundamentally wrong with the way I've calculated the modal loss.
Now, i would attach my script and files that i used to do the calculations, but seems with the new ANSYS format, I can't upload the lms/script files.
Thanks
March 29, 2022 at 10:05 pmTaylor Robertson
I think this argument is a bit dubious, and would check the conversion of kappa using the formulae outline here.
https://support.lumerical.com/hc/en-us/articles/360034917493-Working-with-lossy-modes-and-dB-m-to-kappa-conversion
- Error on Lumerical device
2524
2066
1279
1096
457
