June 29, 2022 at 7:14 am
zz1f17
SubscriberDear Lumerical Support team,
The new version of the Lumerical tools enables co-simulation with Cadance, which is a field I am unfamiliar with. I attended a webinar "Design a silicon photonic ring-based WDM transceiver with EPDA" early this morning. Your team introduced the workflow of the co-simulation, which is wonderful and helpful. But there were too many new features for me to learn in just 1 hour. Can you please share a recorded video with me?
Sincerely,
Zhexuan
June 30, 2022 at 5:59 pm
Guilin Sun
Ansys EmployeeIt is still in process. Once completed the editing, it will be on-demand videos for customers to watch.
July 1, 2022 at 3:09 am
zz1f17
SubscriberThank you, Guilin!
Best regards,
Zhexuan
- Error on Lumerical device
3862
2639
1859
1254
600
