November 16, 2020 at 8:03 am
andrein13
SubscriberHello.
How can I reduce the simulation time? For example, for the attached picture settings, the analysis time takes up to 1 hour to get a graph.
Thank you!
November 16, 2020 at 1:50 pmicellb1
Ansys EmployeeHi, ,nWe are not allowed to click on non-displaying images, could you please attach your screenshot again using upload image rather than upload file? Thank you.nNovember 16, 2020 at 4:26 pmNovember 16, 2020 at 4:56 pmicellb1
Ansys EmployeeHi,nSaving fields at each fine step would definitely cause long solving time, if you don't need to plot fields at each step you can choose to save it at a few time steps of interests. This will largely reduce running time. nNovember 20, 2020 at 2:38 pmviswashh
SubscriberHello there! I am also having similar problem when I do ANALYZE in my WPT system coils. My solver doesn't even solve for 4 hrs. What's the problem?nViewing 4 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8740
4658
3151
1678
1452
