Reference temperature for specific heat for composite cylindrical domain
    • Anadi_Mondal
      I am working on the temperature distribution of a nuclear fuel rod. For uranium dioxide, specific heat changes according to this formula, Cp= 264.256+0.047*T. For Zircaloy-2 specific heat changes according to Cp= 255.66+0.1024*T.
      I plan to write UDF for specific heat according to the description of the ANSYS UDF manual. Like for UO2,
      DEFINE_SPECIFIC_HEAT(cp_u,T,Tref,h,yi)
      real cp = 264.256+0.047*T;
      *h = cp*(T-Tref);
      I have two solid materials. Then, how can I find and set Tref for each material? In Ansys 'Reference Values' the default Tref is 288.16K.
      Anadi
    • DrAmine
      UDF is not required. Just use  temperature dependent cp from built-in formulations.
    • Anadi_Mondal
      Hello Dr Amine,
      Are you recommending writing a 'piecewise-linear profile' for Cp as my original equation for Cp is linearly temperature dependent?
      Anadi
