Reference temperature value
    • FERO86
      I am doing Rayleigh-benard problem simulation inside a square cavity.
      Bottom plate hot, top plate cold, side walls adiabatic.
      In the reference values section can i use, bulk mean temperature as a reference temperature.
    • DrAmine
      Yes the mean is a good value if you are relying on the Boussinesq approximation for the density.
