December 20, 2019 at 5:53 pm
vishnukumargc
SubscriberI am working in a simple problem of flow over model. As the input velocities is provided using parametric option, the reference velocity in setup is automatically not updating itself for new design points. Kindly let me know about the solution.
Flow over model, parametric input velocity, reference value struck with old design point velocity value.
December 23, 2019 at 10:20 am
Ansys EmployeeThe reference value isn't the same as the bc, unless you're using coefficients for post-processing it doesn't matter.
December 23, 2019 at 11:38 am
vishnukumargc
SubscriberI have been trying to calculate the lift and drag coefficient of the model.
The velocity in first design point which i am providing it in parametric option is updating in reference velocity tab in the setup while the second or third design point velocity is not updating in it which is retaining the first design point parametric velocity option for all.
December 23, 2019 at 3:27 pm
Ansys EmployeeThere's probably not an automatic flag to force an update. Have a look in the Calculation Activities menus, specifically the Automatically Initialise & Modify section: you may need to read up on the TUI commands too.
5290
3311
2471
