September 27, 2017 at 11:19 am
admin
Ansys Employee- Open Adapt->Iso Values (If you cannot open Initialize) 2. Options and Inside, and the Iso-values of the "Adaption ..., Cell Refine Level" 3. Press Compute and check the Max value 4. Enter the value of the Max directly into Iso-Min and Iso-Max and press Mark. If you cannot Mark, it may have reached the maximum resolution level. If that is the case, increase the Max Level of Refine by one in Controls. 5. Press Manage 6. Press Exchange, then Adapt
admin
Ansys EmployeeHow do I refine only coarse cells?
5364
3363
2471
1310
1018
