September 5, 2023 at 5:39 am
Handon Um
SubscriberI found a issue that the RCWA result of 5 um regular pyramid array shows a peak in reflectance graph when the relatvie interfaces are more than 15.
But, in the case of unit cell consisted of 4 regular pyramids, the RCWA results shows reflectance spectrum although it is different with the reflectance spectrum in OPAL 2 calculator from PVlighthouse.
Can you let me know the reason why or any solution?
September 6, 2023 at 5:26 pm
Guilin Sun
Ansys EmployeeDo you mean you set 15 interfaces and the result is larger than 1?
Please check all the settings. I tested with 30 interfaces and it is more accurate. Please try 16 or 14 interfaces.
To verify result, you can also use FDTD simulation.
September 7, 2023 at 2:14 am
September 7, 2023 at 2:42 pm
Guilin Sun
Ansys EmployeeThere are other parameters that afffect result accuracy. Please try to usemore k vectors, eg more modes. The interface is to resolve geometry only.
September 13, 2023 at 8:43 am
Handon Um
SubscriberYou replied to me that "Please try to usemore k vectors, eg more modes.". Can you explain specifically about more modes?
I couldn't understand well.
September 13, 2023 at 3:36 pm
Guilin Sun
Ansys EmployeeThis is the convergence testing. How to you justify that the number of the k vectors and the mesh you use currently are good enough to guarantee correct results? you have to do convergence testing with higher number of modes (k vectors) and mesh size.
September 16, 2023 at 7:52 am
Handon Um
SubscriberThank you for your kind reply. I resolved the issue in FDTD.
But, in RCWA, I still can’t resolve the issue that the result shows larger than 1.
I have tested regular array of other structures (eg. tapered wire, cone, pillar, rectangle, pyramid), and only the regular pyramid arrray showed larger than 1.
Is the periodicity of regular pyramid can cause an error in RCWA?
September 18, 2023 at 3:32 pm
Guilin Sun
Ansys EmployeeYou will need to use moe interfaces and probbaly finer mesh, more k vectors. Please follow the RCWA example and do more tests.
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7626
4456
2955
1427
1322
