May 31, 2022 at 8:27 pm
nsingh
SubscriberHi I am trying to simulate reflection from the end facet, here in the example file I see reflection very low compared to what is expected from Fresnel reflection (>1%).
Neetesh
June 23, 2022 at 4:14 pm
Guilin Sun
Ansys EmployeeSorry to reply you late, as the forum is under migration and some posts are locked.
Please try to simulate longer time with smaller autoshutoff min.
Is your simulation single wavelength? please check broadband result and see if the reflection curve is smooth or not. Please paste some screenshots so I can better help you.
- Error on Lumerical device
3648
2512
1737
1226
578
