Photonics
Photonics
Reflection index
    • teddie smith
      As far as I know, there is a parameter called 'reflection index' that relates to the reflection and transmission of a material surface. I wonder what this value is set to in FDTD.
    • Guilin Sun
      Do you mean how to set the material property the refractive index in FDTD?
      If so, there are mainly two methods to assign the refractive index:
      1: if it is a fixed value, or diagonal anisotropic, you can directly assign it:
      2: use the material database. For example, Silicon:
      Please refer to
      https://optics.ansys.com/hc/en-us/articles/360044941894-Material-Properties-Introduction
      https://optics.ansys.com/hc/en-us/articles/360034901473-Rectangle-Simulation-Object
      If you want to calculate the refractive index from reflectance and transmitance you can by whatever the software/script you have at hand. Lumerical software only needs the refractive index or permittivity for simulation. You can import it  https://optics.ansys.com/hc/en-us/articles/360034915093-Creating-new-sampled-data-materials-in-FDTD
