November 21, 2023 at 5:42 pm
November 23, 2023 at 8:37 am
Niki Papachristou
Ansys EmployeeHi Xinyu,
Thank you for reaching out to us! Can you please provide more information on your simulation? A common reason to have ripples and tansmission higher than 1 is the fact that your simulation might not have been completed properly. This can be observed with the auto shut off level: Questions Regarding Autoshutoff level
I hope that was helpful, let me know if I can be of further assistance.Please note that this is the optics forum and not the photonics where lumerical related question are posted. For you next lumerical question please post at: Ansys photonics forumKind Regards,Niki -
November 24, 2023 at 2:08 pm
November 24, 2023 at 2:22 pm
November 24, 2023 at 2:38 pm
Xinyu Liu
Subscriberthe status is 1
November 24, 2023 at 2:41 pm
November 24, 2023 at 4:19 pm
November 24, 2023 at 4:30 pm
Xinyu Liu
SubscriberBTW, the status now is 2. Therefore, I think the simulation time is enough.
November 27, 2023 at 9:08 am
Niki Papachristou
Thank you for your reply. Another common reason is the boundary conditions. What type of boundaries condition do you have?
Kind Regards,
Niki
November 27, 2023 at 2:18 pm
Xinyu Liu
SubscriberHi Niki,
For FDTD, x&y uses Periodic and z uses PML(step angle).
November 27, 2023 at 2:36 pm
Niki Papachristou
It might be worth trying PML and adding some layers. However, this is hard to say without knowing your simulation. Can you send some screenshot of the structure?
Kind Regards,
Niki
November 27, 2023 at 2:42 pm
November 27, 2023 at 2:59 pm
Niki Papachristou
I was hoping for a screenshot from your simulation. Nevertheless, try the suggestion on PML layers. Also you can find more helpful instructions here:
Transmission Results Greater Than One
Kind Regards,
Niki
November 27, 2023 at 3:10 pm
- Working with virtual photometric lab
- Simulation of germicide lamp
- Parabolic reflectors
- Program is Very Slow
- How to test different SOP/VOP with automation?
- Texture Mapping in SPEOS
- Update failed for the Simulation Task component in Speos
- 해결완료
- Light transmission of a system
- xml template file does not apply correctly
8832
4658
3159
1688
1482
