December 6, 2022 at 4:42 pm
Senthilkumar V
SubscriberWhen the simple model simulated for fatigue life study in Ansys mechanical and subsquently in nCode Design life in Ansys 2021R2. The material used is Structural steel. The analysis is solved in Ansys mechanical ,but when the results are exported to nCode, the solution shows solver error. solution sought to overcome this error
December 8, 2022 at 1:56 pm
Manish Dubey
Ansys EmployeeHi Senthilkumar,
Does this appears on this model only or all other model. If it appears on all other model, then it indicates that the results are not saved locally and may be Add-on cannot find them. Solve the Mechanical in the background and solve Design Life locally.
Thanks
Manish
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2656
2120
1347
1118
461
