January 20, 2023 at 4:18 pm
sreejyothi11
SubscriberHi,
I am trying yo obtain the absorption of monolayer mos2 placed over an SiO2(90 nm) layer followed by Si substrate. The material fit of monolayer mos2 is found to have a good fit (PFB). The mesh size used in MoS2 is 5nm*5nm*0.1nm along x, y and z dimensions respectively. But the absorption spectra of mos2 shows a strong difference between the experimental and simulated results. Could you please help me understand the possible reasons for the error?
Thanks
January 20, 2023 at 5:07 pm
Guilin Sun
Ansys EmployeeI did not find the method you used to calculate the absorption. It can be one of the following:
1: use A=1-R-T where R and T are the reflection and transmission coefficient
2: using a spatial 3D monitor to calculate the absorbed power density and integrate it, which is used in solar and opto-electric devices.
I would strongly suggest to use the 1st method and do convergence testing. Please check the material fit also. You can get the fit data by getfdtdindex - Script command.
In addition, please use stackrt to verify the result with experiment: stackrt - Script command
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2656
2120
1347
1118
461
