February 14, 2022 at 6:19 pm
prakashg
SubscriberHello everyone...
I am new to ansys electronic desktop, I have TSMC 180 nm spice model for MOSFET. When I tried to import the spice model, I got three-terminal MOSFET instead of four terminals. There is no option to change the width and length of MOSFET. Please help me to import spice model file and use it Ansys electronic desktop.
Thanks in advance
Prakash
February 15, 2022 at 1:38 pmPraneeth
Did you verify your spice model in any other circuit capable tool and see if it is imported correctly?
Please check whether the spice model has all the relevant information.
All the very best Praneeth.
March 2, 2022 at 7:14 amShaileshRajput
Subscriberddd
March 7, 2022 at 9:57 amprakashg
SubscriberHi I am using this model file for simulation for Project. It works fine completely, It is imported correctly but the problem is I can't change width and length of MOSFET. If you have any reference document for importing model file, Kindly share. It'll be really helpful. I'm Sending model file for your reference.
Prakash
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1285
1096
459
