October 25, 2018 at 6:56 am
Adidash97
SubscriberI am doing CFD analysis of centrifugal pump using MRF model. While running the calculation, it is showing "Divergence in AMG solver:k increasing relaxation sweeps." What does it mean?
October 25, 2018 at 7:01 am
Keyur Kanade
Ansys EmployeeHello,
Can you please give more details about your settings. Can you please insert images of your mesh.
Also please take a look at following for reference.
Keyur
October 29, 2018 at 10:05 am
seeta gunti
Ansys EmployeeHi,
Error tells you that the solver facing issues in solving "k" equation and finally get diverged. You can run with first order discretization schemes for turbulence equations and reduce the Under relaxation Factors. ( by default they set to 0.7, you can reduce to 0.5 and check). If still getting diverged, you can still reduce to 0.4 and run. Check the mesh as well.
Seeta
2726
2146
1357
1150
462
