August 24, 2022 at 1:54 pm
sreejyothi11
SubscriberHi,
- Is it possible to change the wavefront of the source to top hat, Laguerre gaussian, Bessel gaussian and to various modes like TE00, TE01 etc in Lumerical
- Are beam shaping elements available here
Thanks
August 24, 2022 at 3:52 pm
Guilin Sun
Ansys EmployeeYes, you can import whatever the beam shape you want, as long as you have the math expression. Please refer this example https://optics.ansys.com/hc/en-us/articles/360034383054-Using-an-equation-to-define-the-spatial-field-profile-of-a-source-in-FDTD
FDTD is used to design devices so there is no such beam shaping elements available to use.
- Error on Lumerical device
2642
2110
1335
1110
461
