February 19, 2020 at 11:57 am
viochnova
SubscriberHello,
I failed in reproducing of tutorial number 2, especially the part with scalling of heat sink. I did the same steps like in video, but I received different behaviour, see attached video.
How can I achieve the same behaviour like in video?
Thanks for help in advance.
https://discoveryforum.ansys.com/t/18g4cn/discovery-live-thermal-tutorials
Natalie
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
February 20, 2020 at 6:10 am
Naresh Patre
Ansys EmployeeHello Natalie
I tried the tutorial steps associated with scaling and could follow them without any issue.
The video that you attached is somehow not available. Can you attach it again or send it to ansys-discovery-support@ansys.com?
February 24, 2020 at 12:20 pm
Naresh Patre
Ansys EmployeeAfter selecting the top face as direction, click the Scale button then press "Ctrl" key and select the point located at the bottom. This retains the selection of top face as direction as well as the point about which the geometry will be scaled.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3694
2564
1765
1234
590
