October 31, 2018 at 3:42 pm
Swapnil11
SubscriberI did my piping geometry water tight by using fill.
But when I'm doing meshing then it cant happen...After while I gone through ICEM CFD in this tool meshing done when u call it into fluent then it leaves message check- verbosity .so what I have to do now??? -
October 31, 2018 at 4:38 pm
Ansys EmployeePlease can you post some images of the geometry & mesh along with the exact error?
November 1, 2018 at 4:01 am
Keyur Kanade
Ansys EmployeeAre you able to read mesh in Fluent? Cay display any boundary zones in Fluent?
Before exporting from ICEM, please check the mesh and try to fix errors if any.
Keyur
November 1, 2018 at 1:56 pm
Swapnil11
SubscriberI'll snd u images regarding my errors tommorow...
Thanks for ur reply.. -
November 1, 2018 at 2:00 pm
Swapnil11
SubscriberNo. Actually mesh failed during call into fluent. No boundary zones detected..as I mention in my post it leaves the mesh failed n check verbosity...
Ohk I'll try to fix error into spaceclaim n let u know.
Thanks for ur suggestions..
Regards Swapnil
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2600
2088
1319
1108
459
