March 23, 2021 at 6:43 am
jkothavade
SubscriberHow can I find magnetic field strength (H) on any one face(i.e. transformer tanks any one face) in terms i, j,k vectors using string calculator in transient solver (MAXWELL-3D)?n -
March 23, 2021 at 3:37 pm
Deyu Li
Ansys EmployeePlot H field on select face is: n1 change select mode to facen2 select the face you would like to plot field onn3 right mouse click->Fields->H->Mag_HnnField calculator can create Hx, Hy, Hz name expressions, here is an example of doing Hx:n1 launch field calculatorn2 Input Quantity->Hn Scal?->ScalXn Vec?->VecX n Add... ->Hxn3 Select the face in the modeler window->right mouse click->Fields-> Named Expression->Hn
n
March 24, 2021 at 5:39 am
jkothavade
SubscriberThanks for the responsen
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
