LS Dyna
LS Dyna
Regarding Material Model MAT_318 in LSDYNA
    • pdsccmudel
      There is a material model MAT 318 (MAT_TNM_POLYMER) that I am trying to use in LSDYNA R13. It gives me a termination error citing the reason as ‘unrecognized material model’. But this material model does exist in the model library in LSPREPOST and is also prescribed in the R13 manual as well. I wanted to enquire regarding the cause of this error because everything in my model is right.
      I believe someone from LSTC/ANSYS can confirm this. Does this model require an additional license?
      Will really appreciate feedback on this. Thanks!
    • Ram Gopisetti
      Hi , What version of solver are you using ?
    • pdsccmudel
      I am using R13
    • pdsccmudel
      Reminder: Can someone from ANSYS please provide clarification on this query?
      Thanks!
    • Reno Genest
      Usually, if a material requires an additional license it will be specified in the user manual. For example, *MAT_161-162:
      I don't see *MAT_318 in the R13 nor the R14 user manual Vol II:
      But, it is in our DEV user manual:
      https://lsdyna.ansys.com/manuals/
      You can try with R14.
      SMP:
      https://ftp.lstc.com/user/ls-dyna/R14.0.0/
      username: user
      passord: computer
      MPP:
      https://ftp.lstc.com/user/mpp-dyna/R14.0.0/
      If it does not work, you will need a DEV solver. We cannot provide files via the Ansys Forum. If you need the DEV solver, please submit a service request (SR) on the Ansys customer portal:
      support.ansys.com
      Let me know how it goes.
      Reno.
    • pdsccmudel
      Thank you. I will check R14 out and come back with a response.
      BTW , when you look at the material model library in LSPrepost version 4.9, you will find MAT 318 (see image below)
    • Reno Genest
      You can build models using LSPP v4.9 and use any LS-DYNA solver (R9, R10, R11, R12, R13, R14, DEV, etc.). If the material model is not supported by the solver you are using, then it is not going to work.
      Let me know how it goes with R14.
      Reno.
Viewing 6 reply threads
