regarding mesh renumbering
    • Surya2019
      Hello All
      Below I have attached my workbench file.
      Regarding mesh numbering when I use these scope for one body. it is selecting all the other bodies also into the selection. However, mesh renumbering is generated as required.
      for the component Component3solid111, I have selected a mesh renumbering starting from 1. However, the mesh elements are produced in the order like 1,2,3,4,29 but not in the series of 1,2,3,4,5.
      I think the contact elements are renumbering the element to 29.
      I want to export my data into element-wise in sequential order.
      my code for the export is in the solution folder.
       the generated file shows
      ELEMENT ,   1., 0.3419966698
      ELEMENT ,   2., 0.3419387043
      ELEMENT ,   3., 0.3418952823
      ELEMENT ,   4., 0.3418540955
      ELEMENT ,   29., 0.3464401960
      ELEMENT , 13754., 0.7416240573
      ELEMENT, 13761., 0.7415437261
      but the elements should be in sequential order and for the last element it was generating 3 elements
      Could someone please help me in this regard.
    • Govindan Nagappan
      Hi Array nAnsys employees are not allowed to download files. Hopefully another forum member can check the model for younnIn details of Mesh Numbering, you can use compress node numbers to YESnSee if it helpsn
      Add Tags
