February 6, 2021 at 11:36 am
swapnil13
SubscriberRespected sir,
I am running my simulation on cluster.Simulation is running but it is not writing data file. I am attaching batch script and journal file please help me out
February 8, 2021 at 12:13 pmRob
Ansys EmployeeHow is the solution initialised? I'd also recommend always starting the command as n/file/read-case ..... nIt prevents the TUI levels messing commands up as you're using the full command every time.February 9, 2021 at 10:12 amswapnil13
SubscriberHello Rob,nI am doing hybrid initialization. When I load this journal file on my local machine, it is working fine . Data file is also written for given no of iteration in journal fine but for HPC it has problem.nFebruary 9, 2021 at 3:10 pmRob
Ansys EmployeeThere is no initialisation command in that journal. Is the HPC Windows or LINUX?nFebruary 10, 2021 at 5:14 amswapnil13
SubscriberHello Rob,nHPC has linux system. Is there difference when you run journal file in linux and windows .nFebruary 10, 2021 at 5:56 amswapnil13
SubscriberHello Rob,nI had initialized solution by given journal filen; Read case filenrc BH2knotZeroAOAandDrift.casn; Initialize the solutionn/solve/initialize/initialize-flown; Calculate 50 iterationsnit 50n; Write data filenwd BH2knotZeroAOAandDrift.datn; Exit FLUENTnexitnyesn But it is giving error as followsn0: MPT_csend_int: error: file = ../../src/mpcommun.c, line = 1475: mpid = 999999 undefined: Successn0: MPT_csend_int: error: file = parallel/src/para.c, line = 10937: mpid = 999999 undefined: Invalid argumentnnFebruary 10, 2021 at 1:24 pmRob
Ansys EmployeeCheck for white space characters and also look in the .trn, .o and .e files. Re the journal syntax, read my first comment in the thread. nViewing 6 reply threads- You must be logged in to reply to this topic.
5364
3363
2471
1310
1020
