October 3, 2018 at 10:06 am
B SINDHU
SubscriberWhile converting the ansys file to .dxf file some of the slots are not getting converted and i'm getting an error. Can anyone suggest some solution to this problem. Here i have used offline software for converting, if you get to know any online dxf file conversion websites please do reply.
Thank You.
October 3, 2018 at 11:15 am
Keyur Kanade
Ansys EmployeeHi,
What is ANSYS file? Is it SpaceClaim file? You can export .dxf file from SpaceClaim using File - Save As.
Keyur
October 7, 2018 at 4:25 am
Fab237
SubscriberI've tried to import a dxf file geometry but it failed, that issue might have the same source!
thanks
October 8, 2018 at 6:13 am
Keyur Kanade
Ansys EmployeeCan you please give more details.
From where you have exported .dxf file? Is it ANSYS or SpaceClaim? It is still unclear to me. I am not expert in ANSYS as I am from Fluids background. If you can give more details what exactly you are trying to do, I can help further.
Keyur -
October 9, 2018 at 8:23 am
Ansys Employee.dxf import tends to be a bit hit and miss as it's an older format and seems to vary between codes. Depending on the CAD tool, can you export STEP or ACIS? Those are generally more reliable.
You also need to be a bit more specific on which ANSYS product you're using, eg SpaceClaim, DesignModeler, Fluent Meshing etc.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2524
2066
1279
1096
457
