June 30, 2023 at 1:47 am
YANG GUORUI
SubscriberWhen manually defining piezoelectric material parameters, I did not find the definition option of piezoelectric coefficient in the engineering material interface, so I would like to ask how to define this parameter.
At the same time, I also want to ask how to save the material parameters after the definition is completed.
July 3, 2023 at 12:07 pm
Ruturaj Gavali
Ansys EmployeeHey Yang Guorui!
Please refer to this example problem. The model here includes piezoelectric material definition.
Chapter 39: Wire Bonding Ultrasonic Transducer (ansys.com)
Also, refer to the link below to understand how to create new materials and define their properties.
Thanks!
For more information, check out the following links:
July 3, 2023 at 10:08 pm
Bill Bulat
Ansys EmployeeYou might need to turn off "Filter Engineering Data" so the properties other than those needed for whatever type of analysis system you have on the project page are displayed:
Also, at 2023R1, if you open Engineering Data Sources, you'll find a number of predefined piezoelectric materials (poled in the z direction, I believe, and only for 3D models). Please see the image below. You can duplicate any of them and then edit the duplicate with your own material data.
If the version of WB that you are using is old, these options might not be available, and you would either use the Piezo and MEMS ACT or define the material properties with an APDL command object.
Best,
Bill
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
7592
4440
2953
1427
1322
