March 12, 2021 at 4:30 am
Sherin
SubscriberI run a simulation and got results in the result window when I verified the same in between the program running. It worked well and shows correct results.nBut before completing the complete running process the file automatically closed and I didn't find any results when I reopened the same. nMay I know is there any methods to retrieve my results or is there any method to save the results along with its running for avoiding the data loss.nnThanks in advancen -
March 12, 2021 at 6:10 pm
icellb1
Ansys EmployeeHi,nBy using CleanStop you can manually break an analysis and resume from where it's broken, but there is no automatic way to autosave your analysis when there's unexpected closing.n -
March 13, 2021 at 4:45 pm
Sherin
Subscriberok thankyounn
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
