REGARDING THE SIMULATION OF WELD POOL AND MOTION OF LIQUID IN WELD POOL
    • sivateja
      sir, I have developed a moving heat source on the plate which has to be joined in butt configuration. Now I want to simulate the weld pool and motion of liquid in the weld pool which were produced due to the moving heat source. kindly please provide some suggestion regarding this issue.n
    • DrAmine
      Can you add more information about solver to be used as well as a geometrical description?n
    • sivateja
      Sir, I used Ansys workbench for generating the moving source and I used a moving source extension. Now I want to analyse the weld pool formed due to moving source using Ansys.n
      If you're using Fluent have a look at the melting and solidification model. n
Viewing 3 reply threads
