May 16, 2023 at 4:00 am
anhvu lee
SubscriberHi everyone,
I'm doing the research related to the Porous media for trees and have some issues. The porus media doesn't abosrb or block any solar radiation. As the attached files, the wind flow seems to be reduced when meet the tree object, but the radiation temperature inside the tree object still similar to surrounding.
Could I ask you if you find a solution?
May 16, 2023 at 10:48 am
Ansys EmployeePorous media isn't seen by the radiation models, the energy just sees the fluid material.
May 16, 2023 at 11:44 am
Swathi V. V.
Ansys EmployeeHi,
When you said "inside tree object", do you mean the area marked in red? Can you please elaborate your question?
May 16, 2023 at 1:20 pm
anhvu lee
SubscriberHi,
the red dot line is represent for the tree canopy that can not be seen in the simulation results.
Thanks
5340
3325
2471
