September 2, 2022 at 10:42 am
sj21
SubscriberHello, i want to implement a UDS equation( image attached) in a multiphase flow for the secondary phase.
When I compare my equation to the equation in Fluent theory guide ( also attached) , I understand that diffusivity constant should be taken zero and density is constant in my case.
But i am not not understanding how to remove the volume fraction term from the original UDS equation which is given in theory guide.
September 2, 2022 at 11:20 am
DrAmine
Ansys EmployeeWill your scalar be convected by the phase velocity or by the bulk velocity?
September 2, 2022 at 11:28 am
sj21
SubscriberPhase velocity. Velocity vector in my UDS equation is the secondary phase velocity.
September 2, 2022 at 11:41 am
DrAmine
Ansys EmployeeI then recommend to use the bulk equation transport and write your own DEFINE_UDS_FLUX to have it as secondary velocity field. The volume fraction will always appear as you are trying to solve for the phasic UDS. (Like Temperature, Energy, etc..).
September 2, 2022 at 1:59 pm
September 7, 2022 at 6:21 am
DrAmine
Ansys EmployeeBy using an UDF to adjust the Unsteady term.
2656
2120
1347
1118
461
