February 14, 2023 at 12:19 pm
Stanko Čolak
SubscriberHello everyone, I am phD student and I am working my experiment test on Ansys. I am modelling concrete block reinforced with armature, so I don`t know how to make armature as REINFORCEMENT. I am sending two pictures where you can see my problem. I am using Ansys 2019.
Greetings,
Stanko Čolak
February 15, 2023 at 8:22 pm
Bill Bulat
Ansys EmployeeHello Stanko,
By any chance, is your armature a collection of discrete bars that can be represented (geometrically) as line bodies, or perhaps it can instead be modeled as surface bodies with a "smeared" representation of the reinforcing material? If so you might consider reviewing this Help article:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/wb_sim/ds_reinforcement.html
I can't tell from the image you provided whether or not you're trying to use either of the two approaches described in this Help article, but I'm inclined to think this is something you'll at least want to consider.
Kind regards,
Bill
March 14, 2023 at 1:37 pm
Stanko Čolak
SubscriberDear Bill,
thank you for ansvering. My armature a collection of discrete bars that can be represented (geometrically) as line bodies. Should I draw armature as 3D body? I can not get into this link because I don`t know Coustomer ID. Could you download exactly this article and send me on my email (stanko.colak@fgag.sum.ba and stanko1colak@gmail.com).
Thank you.
Best regards,
Stanko
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3670
2550
1749
1226
582
