3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
calculation of relative humidity in hfss
    • Debarati Ghosh
      sir,
      How to calculate relative humidity of textile substrate by using hfss simulation?
    • Mrinmoy Bharadwaj
      Thanks for reaching out to Ansys for your query.
      Although, more elaborate details are needed to reply to your query, I can say that humidity is not a parameter that is present directly in Maxwell's equations and so a direct calculation of humidity might not be possible from EM simulation. However, if the relative humidity can be expressed as a function/expression of one or more of the parameters contained in the Maxwell equations for the medium, you might be able to reverse-calculate the humidity from the evaluated value of the function/exression.
      Hope that helps.
      Have a good day.
    • Debarati Ghosh
      Thank you sir.
