August 23, 2019 at 7:00 pm
camarajoe
SubscriberIs there any way to change the threshold from 0.9 and above to anything smaller? I am trying to add a new material and have uploaded BH curves from experimental data. Attached is the BH curve data. I am able to validate the material just fine but once I try to analyze I get error 'relative permeability smaller than 0.9 is not allowed.'
August 23, 2019 at 7:09 pm
August 23, 2019 at 7:10 pm
mchristi
Ansys EmployeeIt is not physically meaningful (or possible) to have an incremental permeability < 1, which is less than free space (except for diamagnetic/paramagnetic materials).
You may want to double check your data points and units.
- Maxwell, HFSS or Q3D?
- Error
2530
2066
1285
1104
459
