December 1, 2020 at 9:15 pm
mese
SubscriberIn this 3D Fluent problem, we a wall moving upward into a simple domain. The part of the domain which is around the wall is a zone named as Inner and the rest is named as outer zone.
December 2, 2020 at 2:14 pmDrAmine
Ansys EmployeeShare you Dynamic Mesh Setup.nDecember 2, 2020 at 10:09 pmmese
SubscriberI display the related dialogue boxes in bellow pictures. Symmetry_inner and Symmetry_outer are the front and rear faces of the inner and outer bodies respectively. wall_comp is the wall as shown before, interior-face_inner_outer is an interior face between the two bodies. interior-fluid_volume_outer is the Cell Zone of the outer body. nn
Looking forward to hearing from you n
Viewing 2 reply threads- The topic ‘Remeshing is not done for some parts’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
