May 6, 2022 at 9:35 am
oscar.banos_garcia
SubscriberI have noticed that CFX is generating tons of gigabites in files in the .cfx folder.
Is there any risk from removing them?
When and why are they generated?
May 12, 2022 at 5:03 pmRK
Ansys EmployeeHello,
Is this only related to a specific model? Can you do a test case and see if such large files are being written out in the .cfx folder? What model you are running on CFX?
May 20, 2022 at 4:27 pmoscar.banos_garcia
SubscriberI do not know if this is related to a specific model. this is created in the Folder User\Documents\.cfx, not in the folder of any specific model. I cannot reproduce the generation. I simulate everyday, but not everyday they are created. The last one was created some weeks ago. I cannot know what happened or did back then.
Im running just linear CFD with rather complex geometries.
Viewing 2 reply threads- The topic ‘Remove .cfx/CFX_TEMP_XXXX files?’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
