Remove constraint for floating object
    • Brooklyn Varela
      I must add a constraint to my part to run a simulation but I am modelling an object that is supposed to be submerged in water and not touch any surface.
      What should I do? What is the most adaptable restraint then ?
      Forum Moderator
      If it's submerged and can't hit anything does it need to move?
    • Brooklyn Varela
      Hi, yes it is like an underwater robot so it moves in all directions and is submerged in water.
      Forum Moderator
      Right, but what is controlling it's motion in your model? Ie does it need to move or can we assign a flow from the inlet?
Viewing 3 reply threads
