Discovery Import
Discovery Import
Rename the file
    • rg
      Hi
      is it correct that if I change the name of an external component inside an assembly, then the single external file I changed the name does not change?
      I attach a video file to understand better
      Regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Subashni Ravichandran
      Roberto
      That is correct. The external component file name does not change to what you have modified.
