Repair surfaces to create a clean solid
    • peteroznewman
      This video shows how to repair some difficult geometry to get a clean solid.
    • maurya
      thanks sir for your nice video.
                               if one way fails we should switch/ try to new way. this was marvelous approach i learned.
    • FrankD
      The reason you click on planes to get more planes is that often you want to use them as construction geometry to get more advanced datum creations.
      To see what I mean, hold Alt+Shift as you hover over plane references to see a dotted representation, which uses the last two Alt+Shift selected references to make interesting datum creation possibilities -- which can be used as references for actual axis and datum creation in those tools. Here two offset planes calculated the mid-plane:
      For reference there is a good set of help pages on this creation method.
      F
