October 15, 2018 at 3:48 pm
F. Semih Y
SubscriberComputation fails with following message:
Element 3933 (type = 1, SOLID187) (and maybe other elements) has become
highly distorted. Excessive distortion of elements is usually a
symptom indicating the need for corrective action elsewhere. Try
incrementing the load more slowly (increase the number of substeps or
decrease the time step size). You may need to improve your mesh to
obtain elements with better aspect ratios. Also consider the behavior
of materials, contact pairs, and/or constraint equations. Please rule
out other root causes of this failure before attempting rezoning or
nonlinear adaptive solutions. If this message appears in the first
iteration of first substep, be sure to perform element shape checking.
How do I apply the suggested solutions (bold)?
October 15, 2018 at 5:20 pm
SubscriberTo apply the load more slowly, there are two methods that you can use. See this post and the next.
Element shape checking is automatically done when meshing in Mechanical, but it is still good to see which elements are having problems with convergence. That is another change you want to make, and that is to turn on the Newton-Raphson Residual Plots.
October 16, 2018 at 5:49 am
Keyur Kanade
Ansys EmployeeMoving to structural mechanics for better response.
Keyur
October 16, 2018 at 2:53 pm
Sandeep Medikonda
Ansys EmployeeIn addition to what peter mentioned. Can you provide the material model and the Analysis settings you are using if you are still having problems? Here is another interesting discussion on this.
Sandeep
2066
1279
1096
457
